Date/Time: Sun, 23 Feb 2025 22:02:48 +0000
Extending Date Range in Chart Settings
View Count: 493
[2021-02-23 23:27:38] |
Shawn J - Posts: 32 |
Hello. When I attempt to change the Date Range In File in Chart Settings for BTCUSDT-BINANCE, the range will only present itself from 2020-12-18 to the present day. I'd like to see data before this time if it is possible. Thank you!
[2021-02-24 03:13:16] |
That would be correct because that is about when the historical data collection began.
