Date/Time: Mon, 24 Feb 2025 01:28:10 +0000
RUNNING SIERRA CHARTS ON 2 PCS WITH LIVE DATA
View Count: 562
[2021-02-23 20:11:07] |
User918738 - Posts: 31 |
Hi, I would like to run Sierra Charts with Denali live data on 2 PCs. Does Sierra discount for additional PC'S use and Denali data? I understand I will have to pay CME exchange fees for each additional PC. Thanks in advance. |
[2021-02-23 20:35:45] |
John - SC Support - Posts: 38116 |
Sierra Chart software allows for 2 separate computers to be able to run the software at the same time. Refer to the information here: Sierra Chart Purchase and License Information: Licensing / Number of Systems The Denali Exchange Data Feed, however, only allows 1 connection at a time. Therefore, in order to connect from 2 different computers at the same time you would need to add an additional connection. Refer to the information here: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-26 15:13:57] |
Thanks for the response. Next question. Can I configure my order routing of cqg to amp futures thru sierra charts? Or do I need to go thru AMP futures to make the cqg routing connection. I was hoping to to pay sierra charts directly in order to get the two connections on two pcs with denali data and cqg routing. I don't think amp futures will allow me to have the 2 connections on 2 PCs. Thanks in advance. |
[2021-02-26 15:53:55] |
Sierra Chart is not a broker, and you do need to have one to make trades. Therefore, you need to have AMP in the mix in order to get things done. But, you do not need to pay for your Sierra Chart through AMP, you can pay directly to us, and this is the direction we are moving with regards to Resellers/Brokers that make Sierra Chart available. Refer to the post here: Notice: March/April 31, 2021 - Changes to Billing of Sierra Chart through Brokers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-26 17:29:51
