Date/Time: Sun, 23 Feb 2025 22:39:56 +0000
DOM
View Count: 501
[2021-02-23 19:31:04]
User177329 - Posts: 35
Hi, sorry for bothering so much with all this questions.
I am using DOM as an micro-view for entering positions, and i dont know how to add the "%" of all buyers at one side, and the "%" of all sellers at the other side.
Also is there a way that i can add the "+/-" at the price level: example :https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=48508
this is my dom window: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=48504
This percentage i want to add example: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=48505
Date Time Of Last Edit: 2021-02-23 19:32:30
imageScreenshot 2021-02-23 202731.png / V - Attached On 2021-02-23 19:27:45 UTC - Size: 36.23 KB - 215 views
image+-.png / V - Attached On 2021-02-23 19:32:23 UTC - Size: 370.02 KB - 230 views
[2021-02-23 19:47:26]
John - SC Support - Posts: 38116
To add the Percentage of Buyers and Sellers refer to this setting:
Global Trade Settings Windows: Display DOM Depth Percentages (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
It looks like the +/- is the Pulling/Stacking. Refer to the information starting here and the 2 sections after it:
Global Trade Settings Windows: Bid Market Depth Pulling/Stacking - Left/Center/Right Aligned
[2021-02-24 21:44:24]
thank you very much
