Date/Time: Mon, 05 Oct 2026 14:22:28 +0000
Order Positions Discrepancy
View Count: 799
[2021-02-23 16:22:05]
DayTraderEsad - Posts: 121
I am buying multiple contracts and the avg price tends to be correct and then after some time (few hours or over nights) -- the price completely changes. I have added two position I have on MES and MNQ --- you can see that the MES position in Sierra Charts is completely wrong and shows me in profit when it really is not. Which is very misleading and can cause a premature loss or premature profit. the MNQ position is also way off. I attached three picture to show where you have the price and what the price should be.
imageCapture.PNG / V - Attached On 2021-02-23 16:21:06 UTC - Size: 3.42 KB - 317 views
imageCapture1.PNG / V - Attached On 2021-02-23 16:21:16 UTC - Size: 3.3 KB - 315 views
imageCapture2.PNG / V - Attached On 2021-02-23 16:21:26 UTC - Size: 5.46 KB - 311 views
[2021-02-25 15:27:50]
I am still waiting on a response, if this can not be fixed. I will have to leave Sierra and ask for my credit to be refunded please.
[2021-02-25 22:39:42]
In regards to Position Average Price, refer to:
Trading Information Windows: How Average Price for Positions Is Calculated and Used
When you see E after the average price that comes in this case from CQG.
You have the ability to set Sierra Chart always use that price if you want. All of this is fully explained in the link above.
The best service to use is the Sierra Chart Order Routing Service so you have all of the order fills and these calculations can be done accurately:
Sierra Chart / Trading Technologies Futures Order Routing Service
In regards to Daily Profit/Loss, refer to:
Help With Daily Profit/Loss Value
Date Time Of Last Edit: 2021-02-25 22:47:32
