Date/Time: Sun, 23 Feb 2025 21:47:17 +0000
Moving from TT to CQG
View Count: 487
[2021-02-23 15:49:30] |
User299107 - Posts: 58 |
sorry guys, I know you are probably inundated with Q's about this. I followed the instructions re changing the Global Settings>>Data/Trade Service Settings but I wasn't given the (Selectable) Service Settings Window.. Instead I got the "View" Settings window.... I imagine that I have to Open Sierra without it connecting to the current Service in order for me to change to CQG? If this is not correct, can you advise otherwise? Thanks, Eliza |
[2021-02-23 17:12:40] |
John - SC Support - Posts: 38116 |
There is no View service window and an Editable Service window. It sounds like you are just having a problem working with the new windows. Refer to the following for information on how to interact with the new windows: Settings Windows Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
