Date/Time: Sun, 23 Feb 2025 21:54:01 +0000
Individual Stocks are having random tails on candlesticks that do not exist
View Count: 514
[2021-02-23 15:24:55]
User328857 - Posts: 2
I attached an image of TSM, it has 5 tails that do not exist on the actual asset.
imagetsm.PNG / V - Attached On 2021-02-23 15:23:54 UTC - Size: 30.27 KB - 204 views
[2021-02-23 16:54:33]
John - SC Support - Posts: 38116
Follow the instructions at the following link to delete and redownload the data:
Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method)
[2021-02-23 18:46:21]
Update Sierra Chart to the current version:
And make sure the option in Chart >> Chart Settings >> Advanced Settings 3 >> Include Odd Lot Equity Trades is disabled.
[2021-02-23 19:03:19]
John's solution worked, I updated and the odd lot equity trades were already disabled
[2021-02-23 19:16:24]
Re-downloading only worked for a random reason most likely. If you re-download again you probably will see those. And we need to know.
Date Time Of Last Edit: 2021-02-23 19:16:49
