Date/Time: Mon, 24 Feb 2025 22:43:06 +0000
rithmic and test access
View Count: 725
[2021-02-23 15:14:38]
andrew miles - Posts: 21
Hi support,
Sorry if this has been covered but i used sierra for a number of years and then there were many issues with rithmic as the data feed. Rithmic is still my preferred data feed due to trading through one of the prop firms. Can sierra be used with rithmic or not and if so can i test again for a couple of days?
[2021-02-23 23:52:43]
I used support board at least i thought i did. So I guess my original questions still stands as i did not see a reply. Thanks in advance for help
[2021-02-24 03:14:59]
Yes you can use Sierra Chart with Rithmic. You do need the bridge files to connect:
Rithmic Bridge Files
Rithmic is also working on new integration to Sierra Chart which should be available in about a month.
Date Time Of Last Edit: 2021-02-24 03:17:02
[2021-02-24 04:05:45]
thats great news. Can you extend a 3 day trial to me so i can test it out? Fair enough if you cant.
[2021-02-24 07:52:15]
User657945 - Posts: 226
Is there any chance that you will have a SC order rounting to eurex with Rithmic?
[2021-02-24 13:30:06]
Regarding post #4 we have extended your trial.
This will not be with any other service provider. It will be direct to EUREX. There is no reason why we would do otherwise now that we have a presence in Frankfurt, and a relationship directly with Deutsche Borse.
[2021-02-24 14:09:48]
so i connect but it throws me out of RTrader. I also have my chartbooks from before but even though i roll over the contract there are not charts to view
[2021-02-25 23:19:39]
Regarding the disconnection from Rtrader, that is expected.
We are not understanding the second question.
[2021-03-26 15:51:55]
User111634 - Posts: 9
Do you have an update on this?
