Date/Time: Sun, 23 Feb 2025 21:45:47 +0000
TT/AMP Issues, change of Broker
View Count: 634
[2021-02-23 15:12:01]
User422068 - Posts: 5
Due to the issues with TT/AMP, I'm considering a change of broker to Stage 5. Stage 5 has 3 FCM: Gain, Ironbeam and Dorman. Which one can you recommend regards the SC connectivity and order routing? Are there other issues I should be aware of if I change to Stage 5? My questions are all pointing only to the SC connectivity and order routing.
The second broker, I am considering is Discounttrading.com. However, I'm not sure if they use AMP as their clearing FCM.
Would be great, if you could give some feedback.
Thank you.
