Date/Time: Sun, 23 Feb 2025 22:07:28 +0000
Using multiple monitor setup
View Count: 882
[2021-02-23 12:12:52]
User181101 - Posts: 3
Hi there,
I have 3 monitors and I want to open a different chartbook on each of them. It will make monitoring much easier. Could you please let me know how to open different chartbooks on different monitors/screens? Thanks a lot!
Date Time Of Last Edit: 2021-02-23 12:13:14
[2021-02-23 12:45:33]
GravisHTG - Posts: 306
I have 8 monitor and My chartbook opens where I save them. So if Chartbook 1 was in monitor 8 when I save , it will open in monitor 8.
But , you need to keep the same amount of monitor and monitor order as the program remember where it was compare to the whole.
[2021-02-23 13:54:39]
Could you please let me know how you are doing this? I am not seeing any option to open a new chartbook on separate monitor. It just opens in the software in a new tab on the same monitor...
[2021-02-23 14:03:35]
it will open in the place it is first , Then what you have to do is to put your chart where you want. Then , you save all the chart you want under a certain chartbook. Next time you open that chartbook, it will open the chart where they where.
hope this help
