Date/Time: Sun, 23 Feb 2025 21:29:52 +0000
Graphics settings
View Count: 661
[2021-02-23 01:39:35]
User31044 - Posts: 33
Hi - I copied/transferred the Data folder to another PC but when I opened one of my chartbooks the graphics were different (I think they reverted to the default graphics settings you see when you first download/open Sierra Chart). Are they saved somewhere else in the SierraChart folder that I can copy and transfer to my other PC?
[2021-02-23 02:04:15]
User852559 - Posts: 40
Sierra4.config
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
Date Time Of Last Edit: 2021-02-23 02:04:53
[2021-02-23 03:07:41]
Yes that is the correct file. Refer to this help topic:
