Date/Time: Sun, 23 Feb 2025 21:49:04 +0000
problem flux
View Count: 512
[2021-02-23 00:15:05] |
User402518 - Posts: 1 |
Bonjour je souhaiterais continuer à trader en simulation sur l'EUREX qui etait a 21 dollar mais je ne retrouve pas la rubrique pour réactiver mon flux de l'euro bund pouvez vous m'orienter pour que je puisse continuer mon entrainement.
[2021-02-23 03:08:38] |
We have a new much better EUREX data feed now. Follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX Let us know if you require any help with this and we can get that set up for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
