Date/Time: Sun, 23 Feb 2025 21:48:33 +0000
Chart freeze even when my total CPU load is less than 10% and core load less than 50%
View Count: 431
[2021-02-22 22:41:46] |
GravisHTG - Posts: 306 |
I think it my be because of my 4 Moving average - Weigth Volume Move-adjusted on the 1 second chart. ( see picture ) but why its like that ? I want to know because It will help me setup studies and chart so that i can Stop thinking about upgrading my computer ( already have 32GB ram 3000MZ - 3950X - and a GTX 970 ) thanks in advance. |
Attachment Deleted. |
[2021-02-23 19:16:00] |
John - SC Support - Posts: 38116 |
The problem is that when you have a 1 second chart you have a lot of bars, and that Moving Average is calculating across all of them. We have updated that study (and others like it) to have another Input for the Number of Bars to Calculate, which is set to 1000 as the default. If you do not need more than 1000 bars calculated, then you will see the speed of the calculation drop significantly. Look for this change in Pre-Release v 2232. When available, you can update using these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
