Date/Time: Sun, 23 Feb 2025 22:05:11 +0000
volume profile
View Count: 571
[2021-02-22 19:36:27]
User913831 - Posts: 37
I have notice that a volume profile study doesn t show the same volume graph if i overwrite using the Tools, Draw volume profile.
Attached a picture with those results note the aera of volume around the 3920 price.
Can you help
imageES vol profile discrepancy.png / V - Attached On 2021-02-22 19:28:55 UTC - Size: 45.42 KB - 193 views
[2021-02-22 21:05:54]
John - SC Support - Posts: 38116
We assume that you are talking about the image on the left and how the Green/Red profile compares to the underlying blue/red profile (that also matches to the one on the right).
If so, then you need to look at how all the Inputs are in comparison to one another. In particular, we recommend starting with the Input for Bid Volume and Ask Volume Coloring Method. Refer to the information here:
Volume By Price Study: Bid Volume and Ask Volume Coloring Method
