Date/Time: Sun, 23 Feb 2025 21:42:10 +0000
LMAX
View Count: 591
[2021-02-22 18:04:21] |
timokrates - Posts: 28 |
Hi, the demo account I opened at LMAX is number 3******. With that assigned I would be able to test the functionality on both sides, means trading through Sierra but Sierra also retrieves orders and modifications entered on the LMAX platform? Thanks for your help, I just need to be sure that everything works before I can switch from IB to LMAX.. Ingo Date Time Of Last Edit: 2021-02-22 18:04:33
[2021-02-23 11:40:22] |
What is the reason for moving from Interactive Brokers? Our recommendation is to stay with Interactive Brokers for Forex trading. We do not have a good cash Forex service supported. We think it is a mistake going to LMAX unless there is a good financial and functional reason. With that assigned I would be able to test the functionality on both sides, means trading through Sierra but Sierra also retrieves orders and modifications entered on the LMAX platform? Yes if that is your own created LMAX demo account and not one we gave you from a pool of accounts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-23 11:41:31
[2021-02-23 14:57:57] |
The reason for moving is that after account migration from UK to Ireland no leveraged forex trading is possible anymore. Only CFDs. I asked several times what could be done in this case. But IB is far away from being helpful here. So I have to look for an alternative. I you have any recommandations I will be more than happy. |
