Date/Time: Sun, 23 Feb 2025 21:59:40 +0000
i need the simple classic intraday line chart
View Count: 443
[2021-02-22 15:55:04] |
User788130 - Posts: 5 |
I cant find it. it sounds absurd something so simple may not be available. so to avoid any misunderstanding i will describe what it is: line chart: Line chart is used to plot the closing price of a stock. helps to see quickly how the stock price is behaving. It is the one u find on yahoo, google finance etc. what it does is for any transaction closed, regardless of volume etc… it marks in the chart that price at that time. The very basic. thx |
[2021-02-22 19:55:43] |
John - SC Support - Posts: 38116 |
Select Chart >> Graph Draw Types >> Line on Close Refer to the information here: Chart Menu: Graph Draw Types (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
