Date/Time: Sat, 19 Sep 2026 23:55:52 +0000
How to report Bad data
View Count: 797
| [2021-02-22 15:48:35] |
| Recoba71279 - Posts: 23 |
Hi, currently the April 21 Gold contract intraday data is showing a repeat of Friday/Sun action. I have tried several times to delete the April data and reload, but it appears that it is bad from the server. How can we report bad data so that it gets fixed? Thanks |
| [2021-02-22 15:56:22] |
There must be some other explanation for this. For there to be a problem with the data on the server is next to 0%. Provide an image of the chart showing this by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-22 15:56:54
| [2021-02-22 16:31:44] |
http://www.sierrachart.com/image.php?Image=1614011452158.png You can see the action from 2/19-2/21 is duplicated |
| [2021-02-22 17:37:49] |
There definitely is not a problem with the data on the server. That would be next to impossible as we said and we do not see repeated data on the server and there has never been a case of this with the Denali Exchange Data Feed. We want you to delete the chart data file following these instructions: Chart Data and Chart Data Files: Deleting a Chart Data File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-22 17:38:12
| [2021-02-22 17:55:32] |
Deleting the Chart file worked. Thank you FYI apparently there were two GCJ21.scid files, one was GCJ21 and the other was GCJ21.COMEX |
| [2021-02-22 20:18:05] |
Actually that is another thing. GCJ21 is no longer valid. You need to translate the symbols to the current service: Edit Menu: Edit >> Translate Symbols To Current Service The correct symbol is: GCJ21-COMEX You need to use the correct symbol, otherwise the chart will not update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
