Date/Time: Thu, 24 Sep 2026 14:31:03 +0000
AMP account order routing
View Count: 727
| [2021-02-22 15:45:38] |
| mrseho - Posts: 25 |
Hi, I have an account with AMPFutures. My Order routing has been konfigured through you with my data feeds. AMP wrote me, that I have to change my order routing to CQG. I requested the change at AMP and now got login credentials for the CQG order routing without data. How should I set up the denali data feed for using the data and the CQG order routing in Sierra Chart. It would be great if you could please help me with that. Thx, Sebastian |
| [2021-02-22 19:43:18] |
| John - SC Support - Posts: 47994 |
You do not need to make any changes to your data. The only change you are going to make is to connect your Sierra Chart software to the CQG service rather than to the Sierra Chart Order Routing Service. To do this, follow the Setup Instructions for CQG starting at step #6 here: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
