Date/Time: Sun, 23 Feb 2025 21:25:59 +0000
Possible broker solution.
View Count: 444
[2021-02-22 15:43:18] |
User101229 - Posts: 5 |
Hi Sorry to bother you guys. Wanted to know if it was possible to use Interactive brokers as a broker only while using Denali data feed with CQG order routing? Would it be possible? Would it function. Thank you for your time. Joel. |
[2021-02-22 15:58:50] |
Not sure we fully understand this, but Interactive Brokers is supported: Interactive Brokers Trading Service And you can use the Denali Exchange Data Feed with that service: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
