Date/Time: Sun, 23 Feb 2025 21:50:36 +0000
Denali exchange data
View Count: 492
[2021-02-22 15:39:19] |
User904434 - Posts: 57 |
I use "Denali exchange data" from SC - DOM. Last Size column I see always 1,1,1,1,...even when everything change in other columns like recent bid/ask..... - this is not correct - should I change something ?
[2021-02-22 19:36:20] |
John - SC Support - Posts: 38116 |
You would need to compare the Last Size data against the Time and Sales Volume information. Keep in mind that the DOM only updates at the rate set by the Chart Update Interval, so you do not get every single update like you will see in the Time and Sales. Refer to the following: Time and Sales Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
