Date/Time: Sun, 23 Feb 2025 21:58:56 +0000
TT to CQG feed issues
View Count: 448
[2021-02-22 15:39:01] |
User868204 - Posts: 2 |
Hello, I received my login information for my CQG feed due to AMP changing from TT to CQG for order routing. I can't get my charts on Sierra Chart to update anymore (they will load to the correct spot when they open but then they don't move when I watch the chart on Trading View, for example). I also don't know if the DOM works. Anyways, I don't know enough about this yet to troubleshoot, so I thought I would start with asking about my account and if I have the Denali package for data and CQG for order processing? Thanks, Jeff |
[2021-02-22 19:29:10] |
John - SC Support - Posts: 38116 |
It looks like you have not gone through the Setup Instructions to connect your Sierra Chart software to your CQG account. Follow the instructions at the following link starting at step #6: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
