Date/Time: Sun, 23 Feb 2025 22:14:58 +0000
Denali Datafeed and AMP
View Count: 508
[2021-02-22 15:34:55] |
User988942 - Posts: 2 |
Hello I got an email from AMP that Denali TT no longer works with an AMP account. How can I change this if I receive and pay for everything through Sierra. I recently switched to Denali 11 - Advanced + Denali Data Feed. What do I have to do now so that I can keep this date feed? Do I have to change this through AMP or can I do it through Sierra?
[2021-02-22 19:20:52] |
John - SC Support - Posts: 38116 |
It is not the Denali Exchange Data Feed that is no longer supported. It is the TT trading service (Sierra Chart Order Routing Service) that they are not supporting. Therefore, you will be switched to CQG for your trades. But you will continue to get your data from the Denali Exchange Data Feed. There is nothing you need to change in terms of your data. Once AMP has you setup on CQG, then you would just need to go through the Setup Instructions at the following link, starting at step #6, in order to get your Sierra Chart software connected to your CQG account: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-23 03:06:24] |
More information is in this thread here: Questions and Answers Regarding TT (Trading Technologies) and AMP Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
