Date/Time: Wed, 16 Sep 2026 12:48:32 +0000
All the sudden cannot longer connect to data feed
View Count: 720
[2021-02-22 15:29:50]
User788130 - Posts: 5
was working yesterday during day, stop working at night. here the log.
i am new to this platform, no idea if /when/how u can respond thanks
Reading Internal Order ID file. | 2021-02-20 12:11:25.372
Reading Trade Orders file. | 2021-02-20 12:11:25.505
Reading Trade Positions file. | 2021-02-20 12:11:25.508
Reading Trade Account Data files. | 2021-02-20 12:11:25.511
UDPListener (1532). Port 22904 | Listening on UDP port 22904. | 2021-02-20 12:11:25.555
Software version: 2230 64-bit | 2021-02-20 12:11:25.555
Primary Thread ID: 6024 | 2021-02-20 12:11:25.556
Usage end date: 2021-03-05 | 2021-02-20 12:11:25.556
Enabled for: Advanced Features 2. | 2021-02-20 12:11:25.556
Enabled for: Sierra Chart Historical Data Service. | 2021-02-20 12:11:25.556
Enabled for: Delayed Denali Exchange Data Feed. | 2021-02-20 12:11:25.556
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-20 12:11:25.556
Current selected Data/Trading service: GAIN Capital/OEC | 2021-02-20 12:11:25.556
Custom symbol settings values: enabled | 2021-02-20 12:11:25.556
Chart Update Interval: 500 | 2021-02-20 12:11:25.556
Intraday Data Storage Time Unit: 0 | 2021-02-20 12:11:25.556
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-02-20 12:11:25.556
2021-02-20 17:11:25 Local computer time in UTC | 2021-02-20 12:11:25.556
2021-02-20 12:11:25 Local computer time in SC Time Zone | 2021-02-20 12:11:25.556
2021-02-20 17:11:25 Server time in UTC | 2021-02-20 12:11:25.556
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-02-20 12:11:25.556
Program path: C:\SierraChart\ | 2021-02-20 12:11:25.556
Data Files path: C:\SierraChart\Data\ | 2021-02-20 12:11:25.556
OS Version Number: 10.0 | 2021-02-20 12:11:25.556
Locale Setting: C | 2021-02-20 12:11:25.556
DLLs: UserContributedStudies_64.dll | 2021-02-20 12:11:25.556
Allowed protected custom studies: | 2021-02-20 12:11:25.556
(Portion of message log removed)
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-02-20 12:29:10.391
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-02-20 12:29:10.394
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-02-20 12:29:10.394
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2021-02-20 12:29:10.394
GAIN Capital FIX Trading: Connected to FIX server. | 2021-02-20 12:29:10.435
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=ABassetto368. | 2021-02-20 12:29:10.640
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-20 12:29:10.746
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-20 12:29:10.746 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-02-20 12:29:10.747
GAIN Capital FIX Trading socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-20 12:29:10.747
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-02-20 12:29:10.747
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-20 12:29:10.747
GAIN Capital FIX Trading socket (1) | Closed. | 2021-02-20 12:29:10.747
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-20 12:29:10.747
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-20 12:29:10.747
GAIN Capital/OEC | Disconnected from the trading server. | 2021-02-20 12:29:10.747
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-02-20 12:29:10.765
GAIN Capital/OEC | Disconnected. | 2021-02-20 12:29:10.766
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-20 12:29:10.766
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-02-20 12:31:10.769
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-02-20 12:31:10.817
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-02-20 12:31:10.817
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2021-02-20 12:31:10.817
GAIN Capital FIX Trading: Connected to FIX server. | 2021-02-20 12:31:10.858
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=ABassetto368. | 2021-02-20 12:31:11.091
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-20 12:31:11.196
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-20 12:31:11.196 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-02-20 12:31:11.196
GAIN Capital FIX Trading socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-20 12:31:11.196
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-02-20 12:31:11.196
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-20 12:31:11.197
GAIN Capital FIX Trading socket (1) | Closed. | 2021-02-20 12:31:11.197
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-20 12:31:11.197
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-20 12:31:11.197
GAIN Capital/OEC | Disconnected from the trading server. | 2021-02-20 12:31:11.197
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-02-20 12:31:11.206
GAIN Capital/OEC | Disconnected. | 2021-02-20 12:31:11.206
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-20 12:31:11.207
Date Time Of Last Edit: 2021-02-22 20:16:57
[2021-02-22 18:53:33]
John - SC Support - Posts: 47903
The following are the pertinent messages:
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-20 12:13:54.746
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-20 12:13:54.746
Refer to the information here:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
