Date/Time: Mon, 25 Nov 2024 16:52:36 +0000
Setting up second Sierra Charts program
View Count: 1114
[2014-02-26 17:38:49] |
User70416 - Posts: 19 |
I currently use Sierra Charts for free as a customer of Infinity/TransAct. I want to set up a paid account using all your features and use the data from OpenECry. (I have two brokers). I have downloaded a free trial of your program and put it into a file called C:\SierraChart2. I cant log in. I think I need a time extension. I also want to make sure I have all of your features on this free trial. (or I am willing to just pay the fee and get it all). Also, I will not be running both versions of Sierra Charts at the same time. I plan on using the paid version only, once it is set up properly and running. Thank you for your help. Scott |
[2014-02-26 17:51:23] |
We have added 5 days to your own Sierra Chart account. Log into the new installation of Sierra Chart using the same account that you use to log into this Support Board with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
