Date/Time: Sun, 23 Feb 2025 21:45:55 +0000
[Programming Help] - FXView Forex feed - not updated charts realtime
View Count: 500
[2021-02-22 14:45:00] |
User819833 - Posts: 2 |
Hello, the issue of not updating the chart in real time was discussed via email You wrote: >Sierra Chart will make a security definition request and in the security definition response: >Symbol Discovery and Security Definitions Messages >You need to set this : >UpdatesBidAskOnly = 1 >-Sierra Chart Engineering We use Symbol Setting -> check Use custom symbol setting values SierraCharts send 2021-02-22 16:36:08,320 MARKET_DATA_REQUEST :{"Type":101,"RequestAction":1,"SymbolID":1,"Symbol":"EUR/USD","Exchange":"","IntervalForSnapshotUpdatesInMilliseconds":0,"ForDataReplay":0} server responce 2021-02-22 16:36:08,321 TH MarketDataSnapshot: {"Type":104,"SymbolID":1,"BidPrice":1.2147,"AskPrice":1.2145,"BidAskDateTime":1614004568321} There is no security definition request from SierraCharts Sincerely, Alexander Antonenko > > > we have developed a DTC server for the ACT trading platform. We used the > json format. We successfully upload HistoricalPriceData like this > > {"Type": 803, "RequestID": 2, "StartDateTime": 1613377680, "OpenPrice": > 105.35, "HighPrice": 105.35, "LowPrice": 105.35, "LastPrice": 105.35, > "IsFinalRecord": 0} > {"Type": 803, "RequestID": 2, "StartDateTime": 1613377740, > "OpenPrice": 105.35, "HighPrice": 105.35, "LowPrice": 105.35, > "LastPrice": 105.35, "IsFinalRecord": 1} > > and then send feed update messages MarketDataUpdateBidAsk > {"Type": 108, "SymbolID": 1, "BidPrice": 1.3904, "AskPrice": 1.3904, > "DateTime": 1613378015000} > > But the charts are not updated in real time. What else we need to do to > update the charts with every tick |
[2021-02-22 20:31:55] |
Ok we realize in order to get a security definition request sent to your server you need to set this field in the logon response: SecurityDefinitionsSupported Refer to: Authentication and Connection Monitoring Messages: LOGON_RESPONSE [s_LogonResponse structure] Server >> Client Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-23 10:59:38] |
Thanks a lot, everything worked.
