Date/Time: Sun, 23 Feb 2025 21:34:21 +0000
TT and CQG question
View Count: 508
[2021-02-22 13:28:03] |
User807026 - Posts: 86 |
Do I understand right that Dinali will still be my feed and that CQG will only be routing not providing data. I will pay CQG .10 per side for order routing and not Sierra Chart, is that correct?
[2021-02-22 17:55:51] |
John - SC Support - Posts: 38116 |
You are correct that when AMP changes you from the Sierra Chart Order Routing Service (TT) to CQG, that you will continue to get your data through us (the Denali Exchange Data Feed) and your order routing will change to CQG. We cannot speak to the $0.10 per side order routing fee, you would need to ask AMP how that is dealt with when using CQG. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
