Date/Time: Sun, 23 Feb 2025 18:19:29 +0000
CQG Setup
View Count: 605
[2021-02-22 13:24:13]
Ben A - Posts: 123
I sent over a request at the beginning of last week to change to CQG routing due to the TT-AMP issues and as suggested by AMP, however I have not heard anything as yet.
Please could you advise when this may be actioned?
Also, I could not find on the site about fees associated with CQG routing.
Thank you for your help,
B
[2021-02-22 13:50:27]
User921987 - Posts: 238
I was in the same situation waiting for the login details email for several days but because I've been using CQG last year they don't send the login details again. You just have to continue to use the old login details.
If this is not the case then just contact AMP support and they will help you.
Btw. CQG routing fee is $0.10/side and the information can be found for example in AMP's commission calculator
https://application.ampclearing.com/account/commissionquote.aspx?utm_source=hs_automation&utm_medium=email&utm_content=24129786&_hsmi=24129800
Date Time Of Last Edit: 2021-02-22 13:54:55
[2021-02-22 13:56:08]
You need to follow up with AMP about this and fees.
