Date/Time: Sun, 23 Feb 2025 18:40:45 +0000
CQG CME HISTOIRC DATA
View Count: 546
[2021-02-22 03:14:30] |
User642012 - Posts: 58 |
HI I JUST RELOADED MY ES CHART WITH CQG DATAFEED , AS I AM TRADINING WITH ADMIS THROUGH CQG WEB API, AND FOUND THER IS ONLY THREE DAYS OF HISTORTC DATA, HOW CAN I ENABLE HISTORIC DATA ? SO I NEED TO SUBSCRIBE TO DATA FEED THROUGH CME ? BUT I NEED TO TRADDE THROUGH CQG, ONCE I USE CQGWEB API, I CAN ONLY FINE CQG DATAFEED, HOW CAN I USE SEIRRA CHART DATAFEED WHILE TRADE THROUGH CQG ? THANKS |
[2021-02-22 06:34:11] |
You are using Sierra Chart provided data feeds, so the market data will come from Sierra Chart. Make sure this option is enabled: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-22 06:34:30
[2021-02-22 09:10:09] |
HI I HAVE FOLLOW THE INSTRCUTION AS STATED, BUT i can not receive any historic data at all, please advise. Thanks |
[2021-02-22 09:15:05] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
