Date/Time: Thu, 17 Sep 2026 22:11:43 +0000
[Programming Help] - turning a subgraph into a system error
View Count: 1026
[2021-02-21 14:57:59]
User61576 - Posts: 458
pls check the attached code
this was taken from the studies (Ask/Bid Volume Difference Bars) which I am trying to turn into a trading system by using the example in TradingSystem.ccp
when compiling it as is, I am getting lots of errors, but as far as I understand I need to redeclare the variables
Subgraph_Close
Subgraph_High
and
Subgraph_Low
although they were defined few lines above and yet I don't get exactly how to do it.
I hope to get some explanation and assistance
thanks
attachmentTrading_ASK_BID_VOL_DIFF_BARS_V0.cpp - Attached On 2021-02-21 14:57:40 UTC - Size: 5.95 KB - 423 views
[2021-02-21 16:18:13]
ForgivingComputers.com - Posts: 1238
You don't need to redeclare Subgraph_Close, etc. You need to use an array index. You are set for manual looping, so you cannot use [sc.Index].
Subgraph_Close[BarIndex] > 300
Also, you should not use sc.Arraysize as an index:
Subgraph_Close[sc.ArraySize] = 0;
Arrays are zero-based, so you are pointing to an index that is greater than the last index. You should use
Subgraph_Close[sc.ArraySize - 1]
to address the last bar on the chart. Fortunately, Sierra Chart protects you from using out-of-bounds indices, so this is technically ok.
[2021-02-21 19:49:42]
thanks for your replay
the confusing point is what the same use of BarIndex was used successfully with the original example of tradingsystemp.cpp? (the macd crossover which was compiled)
[2021-02-21 19:55:17]
What the documentation does not make clear is that while you cannot use [sc.Index] with manual looping, you can do manual looping when autoloop is enabled.
[2021-02-22 06:03:06]
can it be that the function
sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED
is not returning anything due to the use of index?
[2021-02-22 07:17:35]
Flipper_2 - Posts: 57
  //Trading system based on the above calculations
    //signal long
  if (sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED && Subgraph_Close > 300 && Subgraph_Low < -300)
    //send order
    int Result = (int)sc.BuyEntry(NewOrder); // send the mkt order
    if (Result > 0) //If there has been a successful order entry, then draw an arrow at the low of the bar.
      Subgraph_Buy[sc.Index] = sc.Low[sc.Index] - OffsetPercent * Range;
      Subgraph_Sell[sc.Index] = 0;
  //signal short
  else if (sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED && Subgraph_Close < 300 && Subgraph_High > 300)
    //send order
    int Result = (int)sc.SellEntry(NewOrder); //send the mkt order
    if (Result > 0) //If there has been a successful order entry, then draw an arrow at the high of the bar.
      Subgraph_Sell[sc.Index] = sc.High[sc.Index] + OffsetPercent * Range;
      Subgraph_Buy[sc.Index] = 0;
  else //if no signal condition met, do nothing
This whole code block will not work.
You have the study set on manual looping so sc.Index will not work.
And then the whole block is outside the loop anyway.
And
will not work because you haven't provided an index for the Array, it should be something like Subgraph_Close[sc.Index] or Subgraph_Close[sc.Index - 1] for auto looping (which you haven't set) or Subgraph_Close[Index] if its in the main loop.
You would be far better off making a new study just for the trading system and importing the arrays from other studies that you want to base your signals on using this,
sc.GetStudyArrayUsingID()
ACSIL Interface Members - Functions: sc.GetStudyArrayUsingID()
[2021-02-22 18:32:24]
Thanks for your assistance!
the new study (the system) will inherit the other study's calculations?
is there any known trading example for this?
do I need to set per each value of the other study a different
SCFloatArray StudyReference;
so if I refer to a study with open/high/low/close I will need 4 floats, correct?
[2021-02-22 21:40:41]
Have a look at the example in C:\SierraChart\ACS_Source\TradingSystem.cpp
scsf_TradingSystemStudySubgraphCrossover
That trading system references two study arrays. And yes you need 4 SCFloatArrays not floats.
Just another idea I wouldn't use sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED
Far better to just reference the data 1 bar back then you know it has closed. so the line
would be,
if( Subgraph_Close[sc.Index-1] < 300 && Subgraph_Low[sc.Index-1] < -300)
if using autolooping
[2021-02-23 08:32:18]
I looked on
they also do the same check condition for bar close
if (Input_EvaluateOnBarCloseOnly.GetYesNo()
    && sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_NOT_CLOSED)
    return;
so for learning purposes, how the above is different from your suggested solution of using
[sc.Index-1]
thanks!
[2021-02-23 12:50:43]
Better in what way?
Using
return;
will only process the steps once per bar. Using
[sc.Index - 1]
will process the steps multiple times per bar, and get the same results, but less efficiently.
