Date/Time: Thu, 19 Sep 2024 16:27:36 +0000
color bar if the delta is positive (green) or negative (red)
View Count: 2401
[2014-02-26 16:27:40] |
amk44 - Posts: 10 |
How can I color bar if the delta is positive (green) or negative (red) thanks
[2014-02-26 18:52:09] |
What do you want to determine the difference of specifically?
[2014-02-26 19:43:19] |
amk44 - Posts: 10 |
I use candlestick charts I want the color of the body to be green if the delta is positive and red if negative. Thanks
[2014-02-26 20:38:16] |
OK, but the delta/difference of what?
[2014-02-26 22:16:21] |
amk44 - Posts: 10 |
The delta of the bid ask volume
[2014-02-27 05:02:23] |
For this you will need to use 2 separate Color Bar Based on Alert Condition studies: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s252 These are the formulas to use with each of them: =BV>AV =AV>BV Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
