Date/Time: Sun, 23 Feb 2025 18:16:19 +0000
Unicode-Support in ACSIL
View Count: 652
[2021-02-20 08:11:45]
BrMa - Posts: 80
Dear ladies and gentlemen,
I'd like to print unicode-characters using ACSIL with
sc.UseTool()
and I'm not succeeding doing so, although passing them into s_UseTool::Text (which is of type SCString) using the unicode-format \uXXXX.
I found a post from 2019-11 saying you're working on unicode-support and wanted to finish it about 4 months from then... so in about 2020-03.
Is the support for unicode finished already and am I passing the unicode-characters to SCString in a wrong way? Or is it still not available?
If it's not implemented right now, by when do you plan to have it implemented?
Thanks a lot in advance!
[2021-02-20 15:52:06]
Yes there is full support for Unicode but the encoding that you need to use is UTF-8.:
https://en.wikipedia.org/wiki/UTF-8
