Date/Time: Sun, 23 Feb 2025 18:30:11 +0000
Question about broker
View Count: 438
[2021-02-19 21:44:23]
mrcfc - Posts: 2
Hi, i bought 11 package with denali exchange datafeed but i dont know how to connect with any broker like AMP or other which would be compatible with this data feed
[2021-02-19 22:33:50]
John - SC Support - Posts: 38116
To use Sierra Chart with a broker you would need to find a broker that supports CQG or TT (Sierra Chart Order Routing Service), or you can use Interactive Brokers. Once you find a broker, then you would follow the Setup Instructions for the particular service. You will find the list of trading services here, which include links to the information page of each, which also includes the Setup Instructions:
Supported Data and Trading Services: Supported Services
If you are not going to be using Sierra Chart for live trading, then we recommend using the service outlined at the following link to qualify for the Non-Professional exchange fees:
Easy Solution to CME Funded Trading Account Requirement
