Date/Time: Sun, 23 Feb 2025 18:27:57 +0000
[User Discussion] - Custom study DLLs
View Count: 562
[2021-02-19 17:47:37] |
User459170 - Posts: 262 |
Are custom study dlls posted in the support board safe to use? Are there any security issues one should be concerned about?
[2021-02-19 17:53:05] |
The safest thing is always to have the source code and review it and compile the DLL yourself: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-19 18:08:28] |
Ackin - Posts: 1865 |
You should download libraries from verified authors to which there are references from other users.There are many libraries and source codes here on the forum that are not harmful but are written so "great" that they slow down Sierrachart a lot. When using custom studies, I highly recommend monitoring the study calculating time. Very often you will see very high numbers in milliseconds, this is unusable for live trading ... |
[2021-02-19 18:44:46] |
Thank you so much. Ackin do you know anything about this dll? An Indictor That Will Count Back a Certain Number of Bars? Thanks again. Date Time Of Last Edit: 2021-02-19 19:08:27
[2021-02-19 19:21:29] |
Date of post [2014-01-29 13:17:42] All libraries created before 2020-11-11(SC ver 2195) = will not work, you don't even have to try. |
[2021-02-19 19:27:51] |
btw Here you have a solution via Spreadsheet from Tomgilb or a finished study for download from me: Draw a line from the close 35 bars ago to the close of the current bar |
[2021-02-19 22:25:24] |
//Here you have a solution via Spreadsheet from Tomgilb or a finished study for download from me:// Thanks so much. Interesting intro to spreadsheet study. Thank you!! Date Time Of Last Edit: 2021-02-19 22:33:30
