Date/Time: Sun, 23 Feb 2025 18:28:05 +0000
[User Discussion] - MACD - line/histogram display
View Count: 716
[2021-02-19 16:44:21] |
User276160 - Posts: 3 |
I couldn't find an answer to this in past posts but is there a way to display the moving average lines in front of the histogram, rather than behind them? http://www.sierrachart.com/image.php?Image=1613752678960.png |
[2021-02-19 16:49:22] |
Ackin - Posts: 1865 |
Refer to the following: Chart Studies: Study Display Order |
[2021-02-19 19:54:08] |
User90125 - Posts: 715 |
You could set the histogram to be behind the moving average lines instead... Set the histogram draw style to Transparent Fill To Zero. |
