Date/Time: Sun, 23 Feb 2025 18:54:03 +0000
Chart Trader New Column
View Count: 443
[2021-02-19 16:29:16]
RIFT - Posts: 124
Can you please make a chart trader column for working orders and order fills?
Thx!
Best
P.S I LOVE YOU
imagechart.trader.working.orders.column.png / V - Attached On 2021-02-19 16:28:49 UTC - Size: 83.7 KB - 190 views
[2021-02-19 17:23:16]
John - SC Support - Posts: 38116
As a workaround, one thing you can do is offset the Position Lines to the left a bit by referring to this setting:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TradeDrawingsLeftAlignPercent
And then set your fill space to a position where it will not overwrite those lines:
Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu)
