Date/Time: Mon, 25 Nov 2024 16:53:32 +0000
Some stocks not working on Quote Board or Charts
View Count: 1172
[2014-02-26 16:15:28] |
jdconner - Posts: 27 |
The stocks are MSFT, CSCO, INTC. I'm using IB as broker. Thanks JDConner |
[2014-02-26 18:24:05] |
You need to use the right symbol specification with Interactive Brokers. The symbol needs to specify the primary exchange as well. Refer to the specifications here: http://www.sierrachart.com/index.php?l=doc/IBSymbols.html#Stock Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-26 19:42:28] |
THANKS
