Date/Time: Sun, 23 Feb 2025 18:21:27 +0000
How to change the display format for footbars to show ten thousands and millions?
View Count: 776
[2021-02-19 15:50:59]
stonebridge26 - Posts: 5
Hello everyone! New user to Sierra and currently trying to familiar myself with the software which feels overwhelming right now with all the different settings and customization options. So i am reaching out here for help and would like to know how i can change the number bar charts to display large size, anyting over 9999 i would like to be displayed like 13.2K as an example and for millions could show 1.3M
I looked into the Sierra documention and found that i need to change the value format to "Large Integer with Suffix" but after doing this, i can`t see no change at all on the footprints.
The reason i want to have it displayed like this is because i trade only stocks so if anyone can help me show how to change this i would appreciate it. I want it to look like this https://imgur.com/9ITYGTT
imagefootprint.png / V - Attached On 2021-02-19 15:43:03 UTC - Size: 6.73 KB - 173 views
[2021-02-19 16:36:40]
John - SC Support - Posts: 38116
Refer to this Input for the Numbers Bars study:
Numbers Bars: Use Large Volume Number Formatting
[2021-02-20 21:05:58]
Thank you John, i got it working following the guide you provided.
Also interested to know how i can add the candle body & wicks between the bid/ask on the footprints just like in the pic i attached?
[2021-02-22 15:03:18]
The way the candlestick bar is shown is by using the Study/Price Overlay study, and overlaying the Main Price Graph back onto the Numbers Bars study.
Then you need to change the Graphics Settings - Chart to make the Candlestick narrow for that particular chart.
Also, refer to the following options that are built-in to the Numbers Bars study:
Numbers Bars: Open and Close Marker Style
Date Time Of Last Edit: 2021-02-22 15:05:04
