Date/Time: Fri, 02 Oct 2026 21:14:04 +0000
Number bars Text and background coloring methods with separate compare thresholds
View Count: 738
[2021-02-19 15:08:32]
manfretto - Posts: 119
I use Column 1 background coloring method with defined column 1 range 3-0 up/down (8 colors)
On top of this, I would like to mark imbalances thru column 1 text coloring method.
Is it possible to separate compare thresholds settings for text and background? For example, I need to mark imbalanced bid/ask volume with different colors from balanced one (in total 3 colors - white for balanced bid and ask, green for imbalanced ask, red for imbalanced red). At the same time I need to have all 8 colors for background coloring method - 4 for up and 4 for down.
I can define all colors in Column 1 range 3-0 up/down and Range 3-0 up/down for text.
However, I do not see field where I ca separate compare threshold settings - one for background and one for text.
Does Sierra support it?
[2021-02-19 16:19:11]
John - SC Support - Posts: 48095
Refer to this Input:
Numbers Bars: Use Separate Colors for Text Coloring Method
