Date/Time: Sun, 23 Feb 2025 18:44:07 +0000
Title Bar Name with Variables
View Count: 656
[2021-02-19 11:07:53] |
Botan626 - Posts: 294 |
Sierra Chart Engineering team, please consider adding two variables @Symbol and @Period to expand the functionality of this option. 1. There are really long symbol names, like '^EURZAR-MSFOREX', which I'd like to replace with 'EURZAR', but I'd like to see the bar period as well on the title bar. In this case I'd put 'EURZAR @Period' in the title bar name. 2. I don't need to see the window number at all, and it takes extra space on the title bar. In this case I'd put '@Symbol @Period' in the title bar name. |
[2021-02-19 16:06:06] |
John - SC Support - Posts: 38116 |
You can set a specific Title Bar name for a chart. Refer to the following: Chart Settings: Title Bar Name (Chart >> Chart Settings >> Display >> Chart Display Items menu) The other items would be enhancement requests, and we can't say when we would be able to get to them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-19 16:26:27] |
I know that I can do it. I'm asking you to make this option more convenient in practical use. The other items would be enhancement requests, and we can't say when we would be able to get to them.
Does that mean that you are willing to implement this and that you put this on your to do list? Date Time Of Last Edit: 2021-02-19 16:26:48
[2021-02-19 17:17:09] |
We would like to do everything. Yes, it is on our list, but quite honestly, it is a lower priority than most.
[2021-02-19 17:41:44] |
We will see if we can offer this soon.
[2021-02-19 19:39:22] |
Thanks, I'm happy you liked the idea.
