Date/Time: Sun, 28 Jun 2026 18:20:04 +0000
Forex and tick size
View Count: 927
[2021-02-19 10:00:38]
BenjFlame - Posts: 353
when I set EURUSD chart setting tick size (and price display format) to 0.0001 instead of 0.00001, it still display chart with increment of 0.00001 instead of 0.0001.
Why is that? I would have expected that each tick on the chart itself would be 0.0001.
[2021-02-19 15:52:09]
John - SC Support - Posts: 46920
Tick size and the number of digits to display are controlled separately. Refer to the following setting:
Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
[2021-02-19 16:39:20]
But why when I set tick size to 0.0001 (3 zeros), does the chart still increments in 0.00001 (4 zeros) tick?
[2021-02-19 17:23:53]
That means that the actual data from the exchange is at 4 zeros.
[2021-02-19 17:54:13]
Certainly, but I was expecting I could enforce a zero less. So that is not possible?
[2021-02-19 18:23:48]
If you only want to see the 3 zeros, then you need to change the Price Display Format.
