Date/Time: Sun, 23 Feb 2025 18:27:31 +0000
CME order routing issues with TT -> change to CQG
View Count: 717
[2021-02-19 08:00:31] |
mpva80 - Posts: 14 |
Hi SC team, I have 2 questions concerning moving my account from TT to CQG through the AMP form: https://clients.ampfutures.com/sierra-chart-live-trading-setup-request?utm_medium=email&_hsmi=111754947&_hsenc=p2ANqtz-8uIsqZQWw2qGSuuf87LMfK_iozmR7ScY9ywdaR4OdLmJCgHVkDdzPr3t7srR8qeczV8jkb3H1e-lrokfQTM0emuqm7tg&utm_content=111754947&utm_source=hs_email - First field "Live Trading Setup - Request Type?*": I assume the selection I need to make here is "existing setup - change datafeed". Is this correct? - Last field "Which Datafeed? (Please select all you want Setup) - With Sierra - Denali CQG Datafeed - you will keep Denali as is and CQG will be used for order routing only - No Exchange Data will be enabled on the CQG trader ID*": which option from the dropdown list do I need to select? "Sierra Chart - Denali - CQG - order routing only", or "Sierra chart - CQG"? Thanks in advance! Kind regards, Martijn |
[2021-02-19 15:41:45] |
John - SC Support - Posts: 38116 |
Honestly, we have no idea what to choose for the first item. The choices do not make any sense to us. You would need to ask AMP about that. As to the last item, if you are keeping your Denali Exchange Data Feed, then you need to select the option "Sierra Chart - Denali - CQG - order routing only". As we understand, this will then have AMP change your Order Routing from SC Order Routing (TT) to CQG and leave everything else as it is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-19 16:01:26] |
AD544 - Posts: 64 |
By logic the first option (Sierra Chart - CQG) means the CQG WEB API connection with limited historical data as both data and routing come from CQG Would you confirm that? |
[2021-02-19 16:49:44] |
There are 3 options under the section for "Which Datafeed" on the form. They are the following: - Sierra Chart - Denali - CQG (No Data - Order Routing Only): This would be the selection if you are already getting data through the Denali Exchange Data Feed and just want to change the Order Routing from TT to CQG. - DISABLE All Exchange Data: We assume this is just what it states, but really does not apply to changing the order routing service. - Sierra Chart - CQG: This would be the selection to change Order Routing to CQG and to have the data come from CQG. It would imply that if you are already getting data from the Denali Exchange Data Feed that it would be turned off (if managed by AMP) and data from CQG would be enabled. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
