Date/Time: Mon, 24 Feb 2025 01:20:56 +0000
How to see P/L in currency format using Forex?
View Count: 748
[2021-02-19 03:56:59] |
User570904 - Posts: 3 |
Hi, I need to backtest USD/CAD forex. I need to see the PnL of each trade in currency USD on the attached trading window and in the trade activity logs. I followed all the steps mentioned in this link for Forex: Global Trade Settings Windows: Common Profit/Loss Currency (Global Settings >> General Trade Settings >> General) I already set the PnL as currency in the chart settings. I still cannot see the currency PnL, it just just shows 0 both in the window and the trade activity logs. How to see the profit or loss as a currency? Thanks. |
[2021-02-19 04:28:45] |
Provide a screenshot of what you see. Instructions:https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-19 05:05:25] |
I attached what I see when one trade is in process using the replay feature. On the attached trade window you can see that the P/L is 0, even though the trade is up a lot. The trade activity log also shows a backtest trade I did prior to this current one. That backtest trade I already closed it, but the P/L is zero, which is not correct. |
[2021-02-24 23:52:42] |
Any insights on how to see the P/L in currency format using Forex?
[2021-02-25 14:04:05] |
The problem is you are trading too small an order quantity. This is explained here: Profit/Loss Calculations and Symbol Settings: Order Quantity Effect on Profit/Loss Values for Forex Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-25 14:04:19
