Date/Time: Sun, 23 Feb 2025 18:56:14 +0000
No longer using TT
View Count: 549
[2021-02-19 00:19:56]
User524029 - Posts: 9
Hi, I am currently an AMP and Denali customer and using CQG for order routing now as you guys continue testing TT. I just want to make sure everything is up to date on the Sierra side. Also, I selected the Sierra Chart-Denali-CQG Order Routing only option with AMP and want to make sure that the DOM and reconstructed tape that I am currently using will be accurate with the Denali data.
[2021-02-19 14:49:47]
John - SC Support - Posts: 38116
There is absolutely no difference in the data you are receiving, as you were using the Denali Exchange Data Feed previously, and you are still using the Denali Exchange Data Feed, therefore nothing has changed in this regard.
We see that you have your service set to CQG, so as long as you have the correct information entered for your service, then you should be fine.
