Date/Time: Sun, 23 Feb 2025 18:38:29 +0000
TT Interruption - solution of doubts
View Count: 649
[2021-02-19 00:19:17] |
JCGO - Posts: 10 |
I have read in detail the entire post of "TT Based Order Routing Service: TT Interruption", and I have the following question. I want to continue with data denali, but do I switch to order routing with CQG? or I wait for order routing TT to be solved. It is possible to know when the problem is solved with TT. I appreciate your guidance to know if it is better to wait for TT to be fixed or I switch to denali - order routing CQG Thanks for your help. |
[2021-02-19 02:04:09] |
We recommend waiting until the end of next week if possible until we have CQG set up on the order routing service.
[2021-02-20 01:51:56] |
JCGO - Posts: 10 |
Thank you, I understand what is happening, I will wait for the problem to be solved, I will be attentive to your instructions and comments to be able to trade again, hopefully it will be very soon.
[2021-02-22 15:10:38] |
We have updated information. Support for CQG on the SC Order Routing Service will not be coming. Instead we are focusing on our direct CME routing to get that out as soon as possible. More information is here: Questions and Answers Regarding TT (Trading Technologies) and AMP Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-22 15:11:15
