Date/Time: Sun, 23 Feb 2025 18:33:24 +0000
how to download this file from sierra
View Count: 822
[2021-02-18 22:56:46]
User177329 - Posts: 35
hello, tried to download this links that are shared but it shows nothing basically and dont have a download button or smth..
Swing High and Low
Inside Bar
[2021-02-18 23:03:58]
John - SC Support - Posts: 38116
We are not sure exactly what you are trying to do, but our best guess is that you are not understanding how to add a study to a chart. Refer to the information here:
Chart Studies: Adding/Modifying Chart Studies
If it is something else, then let us know exactly what the problem is.
[2021-02-19 00:00:09]
Yes there is nothing to download. You just need to add those studies from the list of built-in studies.
If they are not listed let us know. You may need to install Sierra Chart again.
[2021-02-19 11:30:53]
Yes i finished download anyway its not what i was looking for...
Guys any idea if i can add support and resistance automatically from sierra chart not free-hand writing?
Date Time Of Last Edit: 2021-02-19 11:36:39
[2021-02-19 12:20:18]
Ackin - Posts: 1865
It's possible download it for free from our CZ/SK forum.
Study: Swing high low pivot line
http://www.sierrachart.com/image.php?Image=1562277515938.png
contact link:
[2021-02-19 16:02:54]
I registered 1h ago but still no email with confirmation
[2021-02-19 16:46:23]
Ackin - Posts: 1865
Done. Check your email.
Registration is manual (due to SC account name verification).
[2021-02-19 16:49:54]
so which is this one to download please i cant find it in the forum?
[2021-02-19 16:55:16]
Ackin - Posts: 1865
the path is in the registration email
1) Download the attached file there
2) Copy and Unpack this file into Data folder in Sierra Chart (default C:\SierraChart\Data\)
- I personally use WinRar for this
3) Run Sierrachart
4) Sierrachart must be version as described in my update or higher....
5) Add custom study
- In Sierrachart / Menu / Analysis / Studies Click on "Add Custom Study" where you'll find new library.
Study name: Swing high low pivot line
[2021-02-19 16:57:48]
Ackin - Posts: 1865
If you have further questions, write me an email or directly to the CZSK forum in the description of the study ...
Have a nice day
