Date/Time: Mon, 25 Nov 2024 16:32:44 +0000
Spreadsheet Alert question
View Count: 1065
[2014-02-26 14:31:43] |
User23815 - Posts: 210 |
I have a spreadsheet alert set up. The only issue I would like to change is that it signals on each bar that the conditions are true. I would like it to signal on the first bar where all conditions are true, and then not signal again until at least one of the conditions switches to false, and then all conditions return to true. I thought this was done with the study setting "Reset Condition on New Bar", which I have set to No, but that doesn't work. I also am set to Yes on Alert Only on Bar Close, and Signal Only Once Per Bar. Do I need to change one of the study settings or do I need to alter the spreadsheet formula? Please refer me to the documentation or explain how to get this result if possible. Thanks
[2014-02-26 18:01:34] |
. I would like it to signal on the first bar where all conditions are true, and then not signal again until at least one of the conditions switches to false, and then all conditions return to true. This is the default operation.Signal Only Once per Bar needs to be set to No. Documentation can be found here: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php If the problem is with your formulas, This is completely outside the scope of our support to help with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-26 18:02:01
