Date/Time: Mon, 24 Feb 2025 04:27:10 +0000
DRAWSTYLE_TRANSPARENT_TEXT - offsetting the text by a positive or negative amount in units
View Count: 707
[2021-02-18 18:49:18]
User79074 - Posts: 105
Since the drawstyle DRAWSTYLE_CUSTOM_VALUE_AT_Y supports "offsetting the text by a positive or negative amount in units", can you please add this ability to DRAWSTYLE_TRANSPARENT_TEXT as well? It would only make sense.
Thanks.
[2021-02-18 18:56:48]
Another alternative that may be easier for you to implement is to allow newlines in the DRAWSTYLE_TRANSPARENT_TEXT. So if you set "\nMY TEXT" this will essentially produce an offset effect.
[2021-02-18 19:43:08]
John - SC Support - Posts: 38116
We just responded to this in another thread. You can always control where you place the text by offsetting it by a set amount of the Tick Size rather than by a percentage of the price.
[2021-03-02 11:44:41]
I responded in the other thread and it was ignored. Please address it. Thread on this page DRAWSTYLE_TEXT with vertical offset that works with vertical scaling
