Date/Time: Mon, 25 Nov 2024 19:34:38 +0000
Number Bars - Bid / Ask Bold Threshold
View Count: 1728
[2014-02-26 14:26:10]
Kefir - Posts: 34
I would like to ask how the Bid / Ask Bold Threshold works in Number Bars.
In the description is written:
Bid / Ask Bold Threshold: This input sets a threshold level, which when exceeded by a Volume value, causes a bold font to be used to display that value.
My chart is displaying ES-march on 3min timeframe and I put trashold number to 300. However, I am not able to get any number highlighted by bold and there are a lot of 300+ volumes on my screen.
Is it supposed to highlight by bold each number in the individual number bar? (e.g. I have in column one bid / ask, in column 2 ask-bid)
Thank you in advance for the answer
Kind regards
[2014-02-26 20:25:28]
We are going to check on this.
One possible problem is that the chart text font you are using is already bolded so you do not see any additional bolding.
[2014-02-27 11:35:06]
Kefir - Posts: 34
Negativ. When I set last price to be bolded it is bolded. Volumes are not bolded (using same format)
Regards
[2014-02-27 17:36:08]
Al SC Developer - Posts: 434
This will be addressed in ver 1098
