Date/Time: Sun, 16 Mar 2025 16:24:10 +0000
[User Discussion] - Chart Scrolling
View Count: 882
[2021-02-17 23:21:00]
58LesPaul - Posts: 429
If I move my finger across the mouse right to left my charts start scrolling and most times it will not stop for a good amount of time. Is there anyway to turn this off? I don't mind the scrolling but it keeps going and won't stop.
[2021-02-19 15:36:05]
ForgivingComputers.com - Posts: 1028
What kind of mouse are you using? My mouse has two buttons and a scroll wheel that also can be clicked. Never seen that problem.
Date Time Of Last Edit: 2021-02-19 15:36:34
[2021-02-19 15:58:46]
A Mac wireless mouse, it doesn’t have a scroll wheel, you just move your finger up and down or side to side. Maybe I can disable the side to side in my Mac.
[2022-08-19 18:54:59]
ivory - Posts: 95
This is quite old, but I had the same problem. This is a MacOS setting called "scrolling with inertia" and can be turned off via Settings > Accessibility > Pointer Control > Mouse Options (or Trackpad Options if that's what you are using)
