Date/Time: Mon, 25 Nov 2024 16:25:37 +0000
Chart Settings saving when using the Quoteboard
View Count: 1289
[2014-02-26 11:30:21]
Trint - Posts: 115
Hello SC,
Thanks for releasing the US Dollar Index Market Stat, great job.
I can't seem to get the 'Price Display Format' and 'Tick Size' settings to save in (Chart Settings >> Main Settings) when cycling through different Symbols in a Quoteboard listing (Chart Linking is set to Symbol only). As far as I can tell everything else in Chart Settings saves ok.
Also, could you consider extending the '-label' row text in the Quoteboard across all columns rather than being restricted to the first. It's just the label becomes difficult to read when using narrow Quoteboards. The colour of the -label row appears to extend.
Regards.
[2014-02-26 17:27:48]
These settings will change and they come from Global Settings >> Symbol Settings.
