Date/Time: Sun, 23 Feb 2025 21:37:50 +0000
TPO Value area lines on lower tf chart
View Count: 594
[2021-02-17 16:12:42] |
User459170 - Posts: 262 |
I put TPO value area lines study on a 1 min chart, the TPO letter time length is 30 minutes, but I get a different Value Area High/low ( the POC value is the same) than if I put the same study on a 30 min chart,. Is this how it is supposed to work? Thanks for your help. On the TPO chart itself, I have turned the Subperiod Style to alphabets, but the chart doesnt diplay properly, I see some weird narrow columns. Looks like I am doing something wrong, how do I get alphabets to show? Thanks for your help. Date Time Of Last Edit: 2021-02-17 16:46:26
[2021-02-17 22:13:58] |
John - SC Support - Posts: 38116 |
Refer to #7 here: Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-18 01:18:39] |
Thanks so much John, so does that mean the 1 minute chart's TPO value is more accurate than the one on the 30 minute chart? Would you please also help me with my other doubt regarding the TPO chart (a separate chart) where I am unable to get the alphabets? Thanks again for your help. |
[2021-02-18 14:45:56] |
In this particular case, yes. It's just that having the exact same time for the chart bar period and the TPO period is where the issue lies. where I am unable to get the alphabets?
Most likely this is just a scaling issue. See if you can expand the chart scales and see the letters. Otherwise, we would need to see an image of your screen so we can understand what may be happening. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-23 14:54:09] |
Thanks a ton John, all solved.
